CONNECTION ISSUES.
Is the only cable available to marry my AC180 to my B80 the aviation to DC7909? Do you have them or alternative suggestions? Also why didn’t the AC180 have 2 aviation portals as many others? THANKS SO MUCH!!
The DC7909 is the only option for your unit. The AC180 does not have an aviation port because it was designed as a simple, low cost budget unit with good performance. There are several higher cost units with the aviation port feature.
