Hi Everyone!
I have an AC200 Max unit that I would like to connect to the generator input for my off-grid cabin. The primary power source for the cabin is a 3 kw single-phase solar power system, which goes through a 240V double-throw transfer switch to the main load center. The second power source feeding the transfer switch is a 30a generator input socket. Since the entire system is single phase, the two legs of the transfer switch are set up to switch the hot leg and the neutral leg of the inputs, instead of two hot legs of a two-phase system. The original neutral bus in the transfer switch is now used as a common ground bus, and the N-G bond is in the transfer switch.
Can I connect my Bluetti to the generator input of this system?
