Hey Guys,
The clocks went forward last night. so we are now in British Summer Time.
My timed charge times did not happen at the times I set. They happened the pre clocks going forward time.
How do I set the app / power station (AL200L) to British Summer Time.
I check my time zone and it says London (UTC +01:00) which I think UTC is the same as GMT? so this should be correct for British Summer Time?
I tried tricking the time zone to show + 2 hours, but that did not work with my tests.
I dont fancy trying to work out setting up the charge times and remembering to set the time minus one hour.
I have the Octopus Agile Tariff which has pricing every thirty minutes, so take advantage of every single cheap moment to charge back up the power station from the evening before.
Advice would be grateful
Simon
Hi @SimonInReading
Please connect by bluetooth to your AC200L and it should sync the timezone from the smartphone.
Let me know, if its worked!
Hi @SimonInReading, We agree with @Selfmadestrom’s opinion. Yes, please connect to the AC200L via Bluetooth—this will synchronize the time zone. Hope this helps.
We hope everything goes smoothly from here!
Hi Selfmadestrom,
Yup that did the trick on both the AL200L and the and AL200PL
Thanks for the little trick.
I assume now that I have connected it to Bluetooth and tested the timed charges it will be OK to use both Bluetooth and WiFi?
Cheap electric from 1pm to 3.30 tomorrow, so I will be checking up when I work to make sure it is playing ball :)
Looking forward to October this year then I can compare to see if these two power stations have actually reduced by bills. yes I know it will take a few years to break even
Simon
