I was wondering if it would be Possible to Charge the B300 with the B230 expansion battery with the D050s Charge Enhancer?
I thought maybe you could take the cigarette lighter port on the B230 hook it up the the D050s enhancer then plug that into the ac charge ports of the B300 battery
Hi @MPtech , We reconfirmed with the engineer and the approach you mentioned is available. But the accessories will be troublesome and the charging wattage is not high. It is more recommended to use that port of parallel port to charge.
