All, when I charge the EB with my car, it only show 001W. I also get same with plug in a 100W solar panel. Is there a reset or firmware upgrade?
TIA
TIA
Very difficult to give an answer without knowing which model of “EB” and a picture of the main screen along with details of how you are connecting or setting up the unit.
Oops. EB55. Just connect a normal 100W Solar panel to the 12v MPPT charging port
Would have to see a pict of your complete connection setup and screen. Something is not making sense and with a little detail, perhaps an answer can be generated. A little detail like what specifically was occurring right before the problem presented itself? Something different plugged in with too high voltage??
Hi @timhosd ,Your feedback has been received, but the following questions need to be reconfirmed with you.
As @Scott-Benson said, the more detailed information you provide, the faster we can identify. Thank you very much for your cooperation ![]()
