I am new to Bluetti. I have two Apex 300’s each with an expansion battery. Hooking them to the Hub A1. Will be adding a 3rd when it arrives. Now when using Hub A1, you can charge all three APEX 300’s (and their attached expansion battery) from one cord on the hub A1. What about Solar or Charger 1 as they plug into the ports on one of the Apex 300’s? What will happen? Will it only charge that one APEX 300 the solar panel or charger 1 is plugged into? Or will it “Spread” to the other two Apex 300’s because they are set up in Parallel via the Hub A1? Or will I have to charge each one separately with the Solar or charger 1?
Hello, Only the connected APEX 300 will charge when a solar panel or Charger 1 is plugged into it. The charging will not “spread” to the other APEX 300 units. You will need to charge each one separately with a solar panel or Charger 1.
I believe that the SolarX 4K is planned to be available with a cable to allow the simultaneous charging of three Apex 300 from one solar input.
