Charging AC200Max from EG4
I have a small off grid solar set up that is controlled by a Victron MPPT and uses an EG4 24v battery, all connected via bus bars. I was thinking I could connect an o-ring to xt90 cable to an open bus bar lug, then connect to bluetti’s xt90 aviation cable, to charge it via the EG4. Will that work?
Thank you,
Mark
Yes, the 24 volts direct from the battery should charge your 200 max fine. If not satisfied with the charging rate received,m you could get faster charging by placing a 24 to 48 volt step up converter between your battery and the 200 max.
