Charger Hanging inverted under shelf
Is it okay to install the charger 1 with screws upside down, base will be flat on wood surface under a shelf. Because of my power station AC180 setup I only have a shelf above it and the Charger 1 will be flat attached to the underside of the shelf. To explain, think of the unit sitting horizontal on a wall but just move it up so now it’s mounted flat on the underside of the shelf.
I have no wall clearance to mount the unit and the only space is the top (underside of shelf) on the area that covers where the AC180 sits.
I’m going to install it, I have no other options, but wonder if others have done this without issues
Thanks Ed
