Charger 2 - Input Overcurrent Alarm
Hello all, recently installed a Charger 2 for charging a Yeti 3000x. I am regularly getting an alarm which is shutting down the charger. Charger Input Overcurrent - G019.
My Yeti lists a max input of 600 watt at up to 50V.
Started at 450 watt at 45V
I was getting an overvoltage alarm early on so dialed the voltage setting down to 25V until I quit getting that alarm.
I have since dropped the max charging wattage down to 350w and it seems to happen less often but still tripping occasionally. At this point this doesn’t seem like a viable solution.
Any suggestions? Maybe its just not playing nice with the Yeti?
Thank you
