I’m almost done building out a van, and the kit I bought uses a Bluetti AC200PL with a Charger 1. Also included are 2 x 100 watt solar panels on the roof. I’ve updated the firmware on both the AC200PL and the Charger 1, and I followed the directions on the app to change the charging voltage from the default setting of 27 volts to 56 volts (default when I select the AC200PL on the list in the app). I get the red light flashing seven times and I’ve gotten the 008 error code. When I manually set the charging voltage to 36 volts, it charges from the engine (which has dual alternators) without any problems. Any suggestions? Do I have a bad Charger 1 unit?
Also, I should mention that I had problems with 36 volts as well until I turned off adaptive charging.
Still getting 008 code when the system is set for 54 volts (default for AC200PL battery bank).
Is this a repair or a replacement under warranty? We got this system as part of a DIY van build kit from Timber Van in Boulder, Colorado. They had it shipped to us from Amazon, so I don’t have an order number. We received it in August, and just installed it last week as we are finishing up our van build.
Not sure if you resolved this issue? I’m in the exact same situation. I believe it’s to do with how the Timber kit combines solar and the Charger 1 outputs. From memory:
Charger 1 set to 40V then it would work without error. But you’re also not getting anything from solar.
Charger 1 set to 56V with no solar input, then it would work without error.
I just installed the Charger 2 and so far seems like a better way to integrate solar and alternator charging.
I’m not in a position to buy a Charger 2 at this point, but will keep that in mind. I’ve found a temporary work around that’s working for me: I leave the negative side of the Y connector disconnected when I start the engine. On the app I watch for the Charger 1 to spool up to 56 volts, then I connect the Y connector and it works every time - I get 56 volts and 500+ watts. No problems with the solar side, and hopefully none will develop.
Thanks for the feedback, and your positive impression of the Charger 2.
Luckily I got the $99 upgrade offer on the Charger 2. It’s nice to be able to have both solar and alternator charging combined with the Charger 1 can’t do.
You might want to consider an isolation switch that would disconnect both positive and negative conductors from your panels simultaneously. Would be safer and easier to do the disconnect.
