Charger 1 slow charge
I have a AC200L. Been working ok. I bought a Charger 1 and hooked up per instructions. Updated the AC200L firmware and BMS using the app. No issues. With my truck running The Charger 1 charges at only 220w. No where near the 500 or so advertised. So I upgraded all of the wiring to ensure large gauge. Same results. All good positive connections at the battery and charger 1. Any suggestions on what could be the issue? The AC200L was at about 80% when I was trying to charge it.
Q’s
  1. Have you configured the Charger 1 using the Bluetti App?
  2. If not you need to set it to the AC200L or Customises to a voltage up to 56VDC.
  3. If you have configured it, what did you set it to?
    When a LFP battery reaches approx 80% its charge rate can slow down.
    Another issue might be that your source alternator does not have the capacity to run the Charger 1 due to other loads or its condition.
Disregard. I found the issue. Thanks!
Steven
