Charger 1 on AC input Port
I already use the AC adapter input port to charge my AC200max from my vehicle battery when driving. I connect it via a D050S charging enhancer thus allowing me to charge off the vehicle & solar at the same time.
Im trying to find out what the maximum voltage that can be applied to the adapter input port on the AC200 max as I would like to replace the D050S with a Charger 1 to get more power from the vehicle system into the AC max.
And yes I know the Charger 1 is usually connected to the PV input.
Dennis
@FannyCamper
Sorry, this should not be feasible. The AC input is 58.8V, while Charger1 has a maximum of only 56V.
