Charger 1 + Multicooler + EB3A + SP200L
Hi all,
I have a Landcruiser that I’m hooking up with a full BLUETTI setup for camping.
Plan is:
  • Solar panel connected to an Anderson plug on the outside of my car wired with 50a auto cable to charge both the Multicooler and the EB3A via the MC4 input connections.
  • Charger 1 output connected into the same 50a auto cable to charge both the Multicooler and EB3A via the MC4 input connections.
  • I will only be using one power source at a time. Either charging with solar panels or driving and charging from the alternator.
Is there any problems or dangers with this setup? Could there be potential problems if the car is started and charger 1 is turned on while the solar panels are still connected? I will never aim to use it this way but I do not want any damage from accidental starting of the car.
Also there is no mention of the Multicooler being compatible with the Charger 1 in any user guides I have read. Can anyone confirm if it is?
Thank you!
@George95 Adjusting the voltage to 16-28V will power the Multicooler, but only if your Multicooler has a built-in B70 battery. You cannot connect the Charger1 directly to a Multicooler without a battery.
All other devices are connected without problems, don’t worry.
