Charger 1 issues
So Ive had the bluetti charger 1 for about a week now. I read the directions and few videos showing how to install it in my 4runner. Installation was easy, no problems. Hooked it up to my ac180 went through the app and it worked great. Charged at 560W. So I go on a 4 day camping trip, leave the solar panels at home and take off. I check every hour on the drive and its keeping my ac180 topped off. Get to the camping spot setup camp go to check the ac180 and its at 78%. I turn on the car and the charger one shows G003 input overcurrent. Definitely put a hinder on the trip now waiting on customer service to help me sort this out. The charger 1 displays the G003 error any time the chaging is turned on whether or not it is connected to a power station. Gonna see if anything changes tomorrow with my eb70s. Tried factory resetting the charger 1 and updating it.
Hi @Redbeard1, For this issue, please log in to the Bluetti app and update all firmware to the latest version.
After that, disable the Adaptive Mode and try again.
Does this resolve the problem?
Hi @Redbeard1, We haven’t heard back from you in a while and wanted to check if the issue has been resolved.
If not, we suggest you contact the support and arrange a warranty service.
Hi Redbeard. I have logged a similar problem with my 2004 Prado and the input voltage over current error. I cannot complain about the customer service as they have been excellent. Let’s stay in touch to see how the issue is resolved
Cheers
Robin
am having the same issue here.
#1 app is updated on both devices
Ac200 elite new model
Charger 1.
Over current erro message
Multiple green blinks upon switching breaker on followed by 24 blinks in 2 blink increments
#set to other in for car battery
Uninstalled the app and various other things the customer service rep made me do.
It did work when i first installed it for an overnight trip. On 12/26/2024 the
Hey same problem here was workimg fine now i have the same over current error code did you get it fixed
@Bajamike Sorry for the inconvenience, the following needs to be reconfirmed with you:
1, There are many kinds of green light blinking, such as blinking when charging normally, or blinking when starting up. Does your Charger1 work properly for charging?
2、Can you provide a video containing the flashing Charger1 LED and the recording of the APP for better troubleshooting by the tech team. :handshake:
The file is to large to share visit the youtube link
Error message
Over current
@Bajamike Hi Miguel, Thanks for the video, this Charger1 is indeed broken and needs to be replaced by contacting the support team.
Please take a screenshot of my reply with the Charger1 SN code and contact the support team at service@bluettipower.com for a replacement. Thanks again for your cooperation!
Hi,
No the issue remains unsolved
Please let me know if yours gets fixed.
Cheer
Robin
My charger 1 is having the exact same problem.
@Vandalfthegray @RobinC
Sorry for the inconvenience.
Please refer to my original post and send the support team the relevant info and video to use for the replacement.
Hi, I also got the over current error. After I did all the updates and disabled adaptive charging
Now, it’s working correctly as long as I haven’t enabled DC output on the Ac200max.
When I do enable DC output, the charger starts and stops every few seconds and makes a short beeping sound, see video.
Is this charger also broken?
I’m having a similar problem but with the red light flashing once every second. It says in the troubleshooting guide that it’s a “startup failed” error but with no offered solution. How do I fix this?
Here’s a video:
Here is a screenshot of the error from the app
I also am having the G002 error. Waiting on a response from Bluetti Support.
Hello bstauth, I ended up doing a warranty claim. There’s no way that error can be solved without sending back the unit. They ended up sending me a new one because it was pretty much still under replacement warranty.
I think this error occurs when you immediately plug the charger back into the power station after changing the voltage. The charger needs to be given time to reboot and recalibrate itself before plugging it back into the power station, 90 or 120 secs i think. Hope this helps.
Thanks. It had been running for a week at the same voltage. Anyway it’s being replaced.
I am now on my second Charger 1 and keep getting this issue
