I have an AC200L and a Charger1. Can the Charger 1 be used in tandem with the solar panel to increase charging capacity?
@Slotown
When using only one power station, Charger1 cannot be used simultaneously with solar panels. Here’s why:
Voltage mismatch: Different DC input sources cannot be safely paralleled.
Risk of damage: The higher-voltage source can overwhelm and damage the lower-voltage one.
Disappointing, but understandable. Thank you.
