Hi! Can you add a charge limit option to the app and the power station? For example, I want to let my power station to charge continuously before 80%, then stop charging.
Hi @palmerov
You actually can set the SoC on some powerstations. But this will only effect the charge by AC not by Solar.
In the smaller units, the only App control re power is to turn AC and/or DC on or off. The other control is to turn the unit off.
Once you turn the unit off, this breaks the Bluetooth connection and therefore you can’t turn the unit back on, and in that, the outputs.
I would suggest that the feature you ask for would require modifications to the internals of the power station as once it is connected to the grid it will charge until full or, until you physically turn off the charging power supply.
I say this as I have had one of my AC180s on grid charge, not fully charged and tried to turn it off via the App. It won’t turn off remotely, because it is connected to the grid which keeps it turned on.
Given that my older 180 is pre password and the newer 2 have this feature means it is either hard coded or probably a different chip set in the electronics. A part charge will likely require internal changes. Maybe in future upgrades. ![]()
