@Selfmadestrom It is fine to use a 48V solar controller to charge EP500Pro, but the input current must be greater than 12A to charge it.
Also, set the DC input source to PV
I want to connect the EP500 Pro to the DC-Load Port of thos Victron. As far as i know you can configure this port when it should be on and it just redirect the Input from the Panels to the Load Ouput. Like a DC to DC Inverter.
Yes, but it becomes a constant current source to charge our machine.
It should be noted that the output current of the solar controller needs to be greater than 12A and that the MC4 header is connected to BLUETTI DC conversion cable
You can configure the victron to passthrough the energy from the solar panels to that load output.
You can set a voltage, when this become active. So when my Battery reaches for example the absorbations or Float Charge, i can use the Panels for charging my EP 500 Pro with full power instead of my batterys with slow float charge.
Its just a Option to actual store more energy over the day.
My next plan is to charge the Bluetti with overflow energy and use it in the night when the solarpanels dont work
