Charge AC 180 and Deep Cycle off one solar panel
I have an AC 180 and a 200 w solar panel with charge controller. Can I split off the solar panel with MC4 connectors into the charge controller to charge the battery and then the other leg going directly into the AC180? Other research tells me to go through the battery and then into the AC180 but I don’t think its clear they know there is a built in charge control.
Welcome bolts20 to the bluetti forum. No you can only have one charge controller on any system at a time.
I wouldn’t split the panel like that. Running one panel into two charge controllers (your external one and the AC180’s built-in MPPT) can confuse tracking and reduce output or cause instability. Best approach is one panel to one controller. Either plug the panel directly into the AC180 and use its internal MPPT, or send it to your external controller to charge a battery and then power the AC180 from that. Mixing both from the same panel isn’t recommended.
