Currently the AC180 has three options for charging. 300, 1100 and 1400 watts. is there any way to customize this? I need an option of 800watts charging. I have an inverter in my truck 1000w so I am restricted to charging at 300watts if there is no sun shining. As well I also have an EB150 which I can use to charge the AC180, but again the EB150 only has a 1000watt inverter so limited to only charging at 300w which is not fast enough. Is there any way to customize the charge speed? With ecoflow you can input any number you want, which seems logical.
Can this be done?
@DaMann
BLUETTI currently offers the option to manually adjust the input current. (For high-capacity models only.)
The password to adjust the input current is 159873. Set the current to be less than the maximum current that can be supplied by the circuitry connected to the machine, including sockets, wires, and circuit breakers.
The input current changes, the power will also change accordingly.
I did not see this option in the AC180 but did see it in the AC200L. Was that feature to limit maximum amperage added or has it always been available for the AC180? I think what @DaMann is referring to with regards to the Ecoflow products is that the charging wattage is easily adjustable by means of a slider button in increments of 100 watts. No password needed and it is right on the main options screen.
Thank you Bluetti admin. Where in the app do I put in a password? I can’t see anywhere in settings where I can input a password. This would be great if indeed true.
@DaMann
I am very sorry for the error info provided earlier.
The option to adjust the current is only available for high-capacity models, and the AC180 does not support it.
