Cart suggestions for moving ac300 system around
Does anyone have any recommendations for a cart to move the ac300 system around ? Was looking for something collapsible if possible with wheels that are large enough to roll on grass or packed dirt …. Let me know if you have any ideas … thanks
Hey @Shellshock
Theese are from Bluetti:
or
Dont think they are that great for grass and mud.
I would prefer something like this:
or
https://amzn.to/3OVmKAW
Using the last one for moving my EP500Pro over grass with a little help from some wood planks
Thanks for the suggestions … I will take a look … I like the hand truck
I used something like this to move it (boxed) up my stairs.
If you don’t have stairs buy a regular hand truck because the extra wheels make turns more difficult!
Note that these are lighter consumer versions for incidental use. There are heavier profi versions that are more durable and better suited for regular use and abuse.
Yeah thats right. Make turns isnt that easy when you have loaded a 80kg EP500 on it^^
But i dont need to move it regulary, so its fine for me
For grass, you need something with big wheels. Take a stroll through Lowes or HD in the garden dept and you’ll see pull carts with wheels designed for working in dirt/grass. Some have sides if you want that.
All the collapsible carts seem to be limited to around 220 pounds. Otherwise a hand truck could work.
https://www.amazon.com/Hihone-Aluminum-Pneumatic-Assisted-Flatform/dp/B08QRFNDVK/ref=sr_1_33_sspa?keywords=moving%2Bdolly&qid=1692214091&sr=8-33-spons&ufe=app_do%3Aamzn1.fos.18630bbb-fcbb-42f8-9767-857e17e03685&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGZfbmV4dA&th=1
