J’ai connecté mon ac200max sur une prise allume-cigare de mon véhicule et il ne charge qu’à 1W…. Tous les autres modes de charge (panneau solaire et 220v fonctionne parfaitement)
La prise allume-cigare fonctionne pour la recharge d’autres appareils (iPhone, iPad…) ou l’éclairage.
Que dois-je contrôler?
Faut-il réaliser un branchement direct sur l’alternateur ?
Merci
I’ve connected my ac200max to a cigarette lighter socket in my car and it only charges at 1W… All other charging modes (solar panel and 220v work perfectly)
The cigarette-lighter socket works for charging other devices (iPhone, iPad…) or lighting.
What should I check?
Do I need to connect directly to the alternator?
Thank you
You should try what @Erebus said. When you say other devices work, the output is on.
The only other thing i can imagine is that your car may reduce the power which get to your AC200Max because the car need the energy for itself. Something like this.
I bought an extension lead and plugged my ac200max into another cigarette-lighter socket. Everything works perfectly at 80W power!
The other sockets probably need to be bridged…
Something else you may want to be aware of if your 12v socket is permanently live in the car like mine. The bluetti will continue to charge from your car battery and drain it. I have a relay switch with a 12v car socket to separate the car battery electronically from the bluetti when the engine has stopped. Or just remember to unplug it. Hope this is relevant and of help.
Bonjour
J’envisage aussi d’acheter la ac200p pour alimenter un fourgon qui serait chargé en solaire et allume cigare. Savez si la bluetti permet la double charge simultanée solaire + allume cigare ? Merci d’avance
I believe that @Mryovo was referring to something that, in the US, we refer to as Voltage Sensitive Relay (VSR). With a cable connected directly to the battery (usually the + post), the VSR checks the voltage coming from the battery. On my VSR (Keyline Chargers ISO Pro140), the relay closes the circuit at 13.3 volts and opens (disconnects) the circuit at 12.8 volts. The relay prevents the house (auxillary) battery or other devices from draining your car battery when the ignition is off. I know there’s an outfit in the UK that sells a similar device. There are a number of YouTube videos that describe the VSR in greater detail. Good luck! I should add that the VSR may not play well with “smart” alternators, which are common on vehicles made after 2014. Check your vehicle’s owner’s manual. (edited).
You can also use something like a LVD, Low Voltage Disconnect. There are a number of options, here’s a link to one: Amazon.com
You can find cheaper options if you don’t mind waiting on shipping. Google “low voltage disconnect”.
