Can you using D050s as a wall charger?
Dear Brain Trusts,
I keep my AC300 permanently inside my car. I was hoping to charge my B300 battery in my house without bringing the AC300.
I’m have recently bought D050s enhancer knowing it’s intent to charge the b300 using solar input:
As I have yet had luck with solar charging, I was wondering if I can use the D050s as a wall charger by using this wall plug ?
@RayGM
The D050S expects DC as its input, I believe.
What you need for what you are describing (to direct-charge a B300 from a wall outlet with AC) is a T500.
If you connect the AC power cord you pictured to the D050S you will destroy it as you will be connecting AC instead of the correct DC voltage and in far higher than allowable voltage.
No, you can’t use the D050s to convert AC into DC for your B300. You will need the T500 instead.
