I am trying to do a basic 12v van system based on the AC200L. I want to do what was doable with the Ac200MAX with the airplane plug going to a busbar and then on to the 12v system. Can I do this with the 12v/10amp cig plug? I plan to run 2 maxair fans, lights, diesel heater, and 12v fridge. If not with the plug is there another efficient way to do this, why did Buletti remove the airplane plug.
@laser166131 You can use a cigarette lighter connected to the RV 12V system, as long as it is not overloaded. Be warned that you basically can’t carry a diesel heater with a cigarette lighter port, and it is recommended that you use the AC port to connect the diesel heater.
The compressor in the fridge also starts at a high power, and with other devices, it is not able to carry.
If you do have to carry that much devices, adding a D40 is more recommended.
