Can You Use 2 Charger 1s on AC300?
Dear Bluetti Community,
AC300 DC charging cable has 4 MCT connections.
Charger 1 requires 2 MCT connections.
Question: can you hook up two Charger 1s to AC300 and run both of them off your car battery?
I’m thinking about buying a couple 200W PV cells to help out the charging while I’m on the road in the typically sunny west coast. But I could save a lot of money if I could just use 2 Charger 1s.
If this is possible, what other reasons might lead you not to use 2 Charger 1s?
Fwiw, I have a Ram Promaster 2500 and I’m pretty sure its alternator could handle 2.
Thanks for your time and consideration.
Sincerely,
I don’t see why the ac300 couldn’t handle it. It’s just 2x54v@560w. The 2 would probably draw about 25A from your alternator.
