Cannot change either DC1 input or DC2 inpur to ‘OTHER”. They both stay on ‘PV” to I can’t charge using auto.
What is the model of power station, and what method are you using to make the change?
@wowaron try disconnecting the inputs after turning unit off, restart with inputs still disconnected and then see if you can make the change. This usually works. Sometimes the input source cannot be changed if there is an input connection.
