Can I use 2 Bluetti PV 120 solar panels with a AC70 Power Station?
Hi I’m new. Can I use 2 Bluetti PV 120 solar panels (120W, 24.4 voc, Isc 6.4A,) in parallel or series with a AC70 Power Station? 500W Max,10A Max, 12V-58VDC? Not sure about the current being too high out of range.
Yes you can in series it will add the volts and in parallel it will increase the amps. And the unit will only draw a max of 10 amp you can go over amps but don’t ever go over volts as that will damage your unit. Welcome to the club and enjoy your new AC70 :blue_heart::blue_heart::blue_heart:
