When charging the Elite 200v2 and AC60/B80 combo the charge indicator charges up to 99 percent full, but continues to charge for quite a long time to reach a full 100 percent. That last one percent takes much longer than the other increments. Any solutions or suggestions to even that out.
Hi @Boboso52, I appreciate your interest in Bluetti.
Yes, it is normal. Generally, when the battery reaches the final stages of charging, it enters a trickle charge mode. This process becomes very slow, as a protective measure to prevent overcharging and potential damage to the battery. It is not necessary to resolve it, battery health is much more important.
If you have any other issues, feel free to contact our customer service at service@bluettipower.com.
I hope you will like the new Elite 200 V2 and AC60/B80 combo.
When the unit is still charging with a large wattage and for a long time at 99% then it may benefit from a calibration cycle.
Bluetti recommends for most models to discharge it until the load shuts down and then recharge it to full using AC utility power to keep the SoC (Battery meter) accurate around twice a year. Here is how it works:
Calibrating only updates battery meter level. It does not change the actual battery capacity.
