Good day Jeffery:
Sorry it took me so long to get back to you. I read your note last night and figured you needed some help, usually I am a little faster on the reply, but was very busy today.
So I am glad you found your bag of parts.
I was going to say you needed a few things first in order to hook any panel up to the AC200MAX.
So this is what you need and most likely have since you found your gear. :
(1)XT90-MC4 cable
(2)XT90 AVIATION CABLE
(3)AND POSSIBLY SOME EXTRA MC4 CONNECTORS
Concerning the actual hook-up and what you need to know.
Stringing the panels together in series is the way to go for now with what you have.
The only thing that can cause damage is over voltage, over amperage is safe as the MPPT controller will manage that.
A simple rule of thumb for stringing your panels together is,
Solar panels that are wired in series have their output voltages added together, while their output current (amperage) remains the same. On the other hand, solar panels that are wired in parallel have their output currents added (increased amps), however, their output voltage will be the same
Your 4 panels each at 19.8 VOC * 4 = 79.2 well below the maximum threshold of the VOC.
Where can I buy additional cables PV cables? The connector on the AC200MAX doesn’t seem to be any kind of industry standard. Now that I’ve found the accessories pack that came with my power station, I don’t have an immediate need, but if I were to need replacements for the accessory cables, where could I find them. I’ve t been able to find them on the Bluetti website.
Where can I find the specs were I to want to make up cables myself? I could easily see myself wanting a cable that went straight from the solar panels to the power station, without the intermediate XT90 connection. The precise connector specifications and pin out should be in the manual, but it isn’t. Is it somewhere online?
