Hey everyone!
This thread should be use for known bugs in the firmware and the latest firmware updates for the EP Series of Bluetti Powerstations and Home Storage systems.
For fill this thread with information, i need your help!
Please report your current unit, Region and installed firmware. If you facing any bugs with you unit, please also provide this informations with a error description. If the same error is reported multiple times, i will include this as “known bug” into this thread.
Hope this leading to more transparancy within the community and maybe is also a great help for the bluetti devolopers to see what problems some firmware may have and fix them much sooner.
Please use this kind of format to comment this thread:
Unit name: EPxxx
Region: EU/US/CA/JP etc.
Current firmware: ARM: xxxx, BMS: xxx, and so on.
Current Problems: Please provide a short description of what you problem is currently
Thanks in advanced to everyone who is helping!
Overview
EP500/EP500Pro
Region: EU
Current Firmware: IOT v9041,03 - ARM v4039,05 - DSP v4038,07- BMS v1020,01 (EP500 Pro)
Known bugs: ./.
Region: US
Current Firmware:
Known bugs:
Region: CA
Current Firmware:
Known bugs:
Region: JP
Current Firmware:
Known bugs:
EP760
Region: EU
Current Firmware:
Known bugs:
Region: US
Current Firmware:
Known bugs:
Region: CA
Current Firmware:
Known bugs:
Region: JP
Current Firmware:
Known bugs:
EP760
Region: EU
Current Firmware:
Known bugs:
Region: US
Current Firmware:
Known bugs:
Region: CA
Current Firmware:
Known bugs:
Region: JP
Current Firmware:
Known bugs:
EP800
Region: EU
Current Firmware:
Known bugs:
Region: US
Current Firmware:
Known bugs:
Region: CA
Current Firmware:
Known bugs:
Region: JP
Current Firmware:
Known bugs:
EP900
Region: EU
Current Firmware:
Known bugs:
Region: US
Current Firmware:
Known bugs:
Region: CA
Current Firmware:
Known bugs:
Region: JP
Current Firmware:
Known bugs:
@BLUETTI_CARE @BLUETTI Can you pin it to the top? Thanks!
Unit name: EP760
Region: ANZ (Authentication settings)
Current firmware: ARM: v5023.17, DSP: v5022.14, IOT: v9043.05
Current Problems: This fault is very intermittent. It has only happened 2 times since the system was installed on 17th October 2024. My system is Grid Connected with an AC coupled solar system.
The issue is that the Bluetti app (v2. 3.11) connected via Wi-Fi. stops displaying energy flow and levels. The “PV” and “Consumption” values do not change despite the fact that the loads and PV generation are changing. I know that loads are changing as my solar system has a separate app showing real time changes in PV generation and AC consumption.
I believe that the EP760 is handling loads correctly when this display fault occurs.
If I wait long enough, I do see the battery percentage change correctly.
In this faulty state, I am unable to access the EP760 system settings via Wi-Fi. If I press on the settings icon on the Bluetti app, nothing would happen.
Note that at this time, I was able to connect to any website and my solar system app which uses Wi-Fi was working normally implying that my Internet connection was working fine. However, just in case, I tried rebooting my Internet router but this issue remained the same.
I then tried to connect via Bluetooth to the EP760 and I was then able to access the EP760 settings, however the energy flow display was still not working correctly. It did show an energy flow but it was not correct and when I changed loads the energy levels stayed the same.
I tried turning the EP760 “System Switch” off then back on via the app, but the issue stayed the same. It displayed the same incorrect energy flow and levels as before.
It was only after I completely turned off the system including batteries, EP760 and the AC grid connection, then turned it all back on again that this issue was fixed.
Screenshots below show display when connected via Wi-Fi and via Bluetooth.
Hi @Lyndon_S, Please refer to the following video link and start from 5:04 to follow the troubleshooting steps.
EP600/760 troubleshooting video: https://youtu.be/P0XB9dCZbtQ
I hope it does help.
Next time this issues occurs, I will try the suggested reset method as per the video.
However, this doesn’t address the actual issue.
I will update the IOT module in my EP760 from 9043.05 to 9043.13 and then update the Bluetti Android app to 2.3.12 to see if this solves the issue.
Hi @Lyndon_S, I appreciate your kind understanding and patience.
We believe the new firmware should help resolve the issue.
We hope everything goes smoothly.
Unit name: EP760
Region: GERMANY (Authentication settings)
Current firmware: ARM: v5023.21, DSP: v5022.17, IOT: v9043.14
Current Problems:
My whole house installation is connected to the backup-output of the EP760. Before the firmware upgrade the unit worked flawlessly (at least with the problem that occured after) and also my house installation works perfectly when connected to mains.
Upgraded the firmware today from ARM 5023.20 to 5023.21 and DSP from 5022.16 to 5022.17. After resetting the device as soon as the device switched on the “backup”-output my RCD tripped which is connected between backup and my house installation. Now everytime I try to use the unit the RCD trips as soon as the EP760 is connected to mains with a load on “backup”. In addition, I get various error message like B002, B006, B050 and even B040 although there was nothing conneceted to backup. System is now useless after the last firmware upgrade.
Update: it seems like the update or something shortly after it destroyed the electronics of my backup-output
Hi @mbrandhu
Can confirm that the latest EP Updates seems to be faulty. I did see similar description on Facebook for EP600.
@BLUETTI_CARE @BLUETTI : Could you give that feedback to the R&D Team?
That post in Facebook is from me
Hi @mbrandhu, Yes, we indeed found your Facebook post and email. Our engineers are already following up on this matter.
If you believe this is related to the update, we can attempt to roll back to the previous firmware. We can also arrange for repair services. Rest assured, we are committed to resolving this issue for you.
Thank you, @Selfmadestrom, for your attention and helpful response.
Hi @Lyndon_S, We haven’t heard back from you in a while and wanted to check if the issue has been resolved after upgrading.
Hi @BLUETTI_CARE,
Thank you very much for the follow up. I really appreciate it.
I haven’t done the upgrade of the IOT module from v9043.05 to v9043.14 on my EP760.
The reason is that I am afraid that I will lose all of the energy statistics and dollars saved statistic that have been generated since the system was installed. Can you please help me understand where this information is stored and why it can disappear when upgrading the IOT module and the Bluetti app from 2.3.11 to 2.3.12?
Also, before I do the upgrade, I would also like to know whether, if something goes wrong, is there a way for me to go backwards from IOT v9043.14 back to v9043.05? Or is that not possible?
On the whole, I am quite pleased with the Bluetti EP760 system with the current versions of firmware. The only minor issue that I have seen (and reported to you) has only occurred 2 times. This is where the energy levels stop updating on the app. Whilst I would like this to be resolved, I definitely don’t want to make any changes that make the system worse.
Looking forward to any advice that you can give me.
Kind Regards,
Lyndon
Hi @BLUETTI_CARE,
As an EP760 user in Australia who already is wary of the Bluetti firmware update process, it is concerning to read that a firmware upgrade has possibly led to a hardware failure on @mbrandhu system. Are you able to provide us with an update on this problem? Can you please detail what factory QA testing is in place for new firmware releases?
Thanks, Lyndon
Hi @Lyndon_S, We are more than happy to assist you. You can choose to upgrade the firmware, and if you are not satisfied with it, we can arrange for a rollback to the previous firmware. Data will be stored on the app server, so IOT data will not be lost after the upgrade.
The issue mentioned by mbrandhu seems to be an occasional short circuit problem. Our initial assessment suggests that this is unrelated to the firmware upgrade. The short circuit might have been caused by the usage scenario or temporarily unstable grid conditions at that time.
We will need to test the product again once the return is processed.
Rest assured, we take full responsibility for our products and firmware. If any issues arise after the upgrade, we will resolve them.
It seems like the hardware fault already occured before the firmware update. I had a short on the live-line between grid and backup. Why - nobody knows. As long as I was connected to the grid, the EP760 synchronized its sine waves to the grid-sine-wave. After the update the unit rebootet, thus lost its synchronisation to the grid and so the defect was ovious, it just was undiscovered before due to the grid-sync. That at least is my theory. Bluetti support reacted quickly and replaced my EP760 within just ten days. Great service here! It seems my defect was a pure hardware problem and not in any way a problem with the firmware.
@BLUETTI_CARE @Selfmadestrom
Gentlemen,
I have finally decided to upgrade the firmware on my EP760 system and also my Bluetti Android app. I have a question regarding the correct order to upgrade my system.
Specifically my Android App is prompting that:
IOT: (This has a separate “Upgrade” button)
IOT v9043.05 → v9043.15
SYSTEM: (This has a separate “Upgrade” button)
ARM v5023.17 → v5023.21
DSP v5022.14 → v5022.18
BCU v1025.16 → v1025.19
And when I open the Android App it is prompting me to upgrade to V2.3.15 (my current version is 2.3.11).
What is the correct/recommended order to do this upgrade?
For example, is the correct upgrade order: IOT, then SYSTEM, then App?
Also what fixes/features are included in the new versions of ARM, DSP and BCU?
Hopefully you can provide me with some information to alleviate my anxiety about doing this upgrade. Note that I am currently reasonably happy with my EP760 system and I certainly don’t want to introduce any new issues.
Kind Regards,
Lyndon
Hi @Lyndon_S, We agree with your opinion. Yes, please upgrade in the order you mentioned.
The new firmware pushed in batches has undergone multiple tests, so it is safe to upgrade. Rest assured, this will not cause new issues.
New DSP v5022.18 Features: Adjusts the relay operation sequence when switching between grid-connected and off-grid modes.
New ARM v5023.21 Features: Enables generator start-up when the default certified country is set to Australia. This firmware is not necessary for non-Australian customers.
New BCU v1025.19 Features: Optimizes the RSD emergency stop issue for North American regions. This firmware is not necessary for non-US customers.
EP500/EP500Pro
Region: EU/Germany
Current Firmware: IOT v9041,10 - ARM v4039,05 - DSP v4055,03- BMS v1020,01 (EP500 Pro)
I got some Bluetooth crashes with my EP500pro from time to time. ![]()
The device lost connection to my RasPi5 with HomeAssistant installed. Turning BT on/off didn´t help me to connect my phone with the device. After some time with some on/offs/ons the device will be found with my phone (Samsung S24 Ultra) but cannot connect.
I must turn off the EP500pro and restart it, after that the BT connection works fine for some weeks/month until the next BT crash appears.
Why is Bluetti not able to make a WLan gateway for HomeAssistant? Or like Anker and other brands a way to control WLan switches like shelly when neccessary? ![]()
I need a stable connection, cause I have a automation which charges the battery when the bat is under 20% load, then a shelly starts charging the battery with grid current until 80%. I connected my Fridges to the EP500pro and use it as USV, so it must be working 24/7/365 without big fails, cause the 2 fridges are fully loaded…
So time for a vote for better WLan switch support!
Kindly regards
Tobi
