#BLUETTISwapSolar Ac180t and cooler ideas
#BLUETTISwapSolar
My family love to go wild camping especially my daughter, who is in a wheelchair and space is at premium when we go camping. as we need to take lots of medical equipment and supplies with us.
Swappable batteries in the ac180t is a fantastic idea,you could run the unit 24/7 and swap out the battery without turning off the unit. Especially good for medics equipment.
For example, when one of the batteries runs low, you can conduct non-interrupting maintenance by swapping it with a fresh battery in a matter of seconds.
Unlike internal battery technology, a hot-swap battery doesn’t need a professional technician to change the battery or conduct regular maintenance. The battery LED indicator displays each battery’s charge status and time remaining; for instance, also the shipping costs are greatly reduced because if one battery developed a fault that’s all you would need to send back leaving you still with a working ac180T to use and the unit running on one battery.
First the bluetti cooler- ice maker. Awesome Looks wonderful. Great size and long run time. Would love the ability to put a mobile SIM card in it that would allow you to access the unit from anywhere and access information like temp,battery status, also built in speakers for music.
Also the ability to half the cooling compartment. When you start your trip the cooler will be full but the further you get into your trip the cooler might only be half full I the ability to only cool one side of the cooler would also extend the runtime of the cooler.only half the cooler to cool.
Now for the AC180T hope I can explain this do you understand.
To make the ac180t a unit for all things. My ideas are
  1. Built in sim card to access the unit remotely either when camping or at home so you can access the battery status,and internet access for the kids.
  2. Built in speakers for music or you could add a microphone for calls.great for emergency situations.
  3. Now the battery so you went camping,overlanding, caravanning the unit is bigger than the ac180 so can’t really take it that far. So going out a trek ,walk. The battery would split in half(push latch forward full battery comes out pull latch back only half the battery comes out ) leaving you with a small portable bluetti half the size and half the weight of the original battery. Also two usb on the half battery ideal for when you’re away from the main unit to charge phones ,camera,drones.
@Ktt Thanks for the input.
#BLUETTISwapSolar welcomes its first entrant!
