Subject: BMS locked in sleep mode after power outage – request for solution or replacement
Hello Bluetti Support Team,
I would like to ask for your assistance regarding an issue with my Bluetti power station.
I purchased the unit, and after approximately three weeks of normal use, during a power outage the station entered sleep mode and could not be woken up by any method. No button combinations or standard procedures worked.
At one point, I supplied 12 V to the standard input, after which the station powered on and requested a firmware update for several internal components (not the BMS controller). The update completed successfully using the official procedure. However, after some time, another power outage occurred, the station went to sleep again, and this time it has never woken up since.
I created a topic on the Bluetti forum but did not receive any response. Since Bluetti does not provide official service in Ukraine, I was forced to look for third-party service centers, where the repair time was estimated to be at least one month. Therefore, I decided to disassemble the station myself in order to understand the root cause.
After disassembly, I found no visible signs of damage. I accessed the battery compartment and checked all battery cells — they are well balanced, and the battery pack outputs 54 V. There are no short circuits on the power output.
I then supplied power to the 5-pin diagnostic connector on the BMS board. The board powers up and the LEDs blink, indicating that the logic is alive, but no further action occurs and the P output remains locked.
I would like to ask Bluetti:
Is there an official method to recover the BMS from this state?
Is it possible to order a replacement BMS controller board, either as an exchange or for purchase?
What would be the correct procedure to resolve this issue?
Thank you very much for your time and support.
