Bluetti @IFA 2025
Hey everyone!
This years IFA was… FANTASTIC!
Here are some pictures and a realy well captures video from the event :slight_smile:
Thank you for sharing your excitement about this year’s IFA! We’re glad to hear you had a fantastic time. We’d love to see the pictures and video you captured from the event!
Will you post some specs for the fridge power unit soon?
Hi @paulr
Sure! Here are the specs for FridgePower:
Rated Power: 1800W (120V US/CA), 1800W (230V EU/UK/AU)
Power Lifting: 3000W
Surge Power: 3600W
Battery Capacity: 2016Wh
Cycles: 4000 to 80%
Max supported Battery Expansion: 8064Wh (4 Packs)
Idle load: <7W
UPS switch time: <10ms
Dimensions (L x W x H): 350 x 580 x 75 mm or 13.8 x 22.8 x 3 in
Weight: 19 kg or 41.9 lbs
Hope that is everything you need :)
I think a lot of us are curious about the exact specs especially things like startup wattage, continuous output, and how it handles compressor cycles. Fridges can be tricky with those power spikes, so having clear numbers would make planning setups much easier.
Hi @poyiyo14
Maybe this is interesting for you:
https://www.kickstarter.com/projects/bluetti/fridgepower
