One of the fans in my unit is making a light clicking sound. I use the unit on a daily basis so I’m hoping there is some type of fix for solution for the problem.
From what Google Gemini says there may be a firmware fix for users with this problem. I didn’t know what type of information you needed from me or if I should post my serial number or other information here in the forum. The light clicking sound sounds like a fan spinning and lightly touching a wire or something. I haven’t removed the fan panel to check and see, but can do so if you advise.
