Bluetti eb70
Can the EB 70 be used to power a sump pump drawing 260 watts for up to 3 minutes on/off cycle time? The EB70 is plugged into a mains outlet and is needed to cover any power outage from the mains supply.
Hi @Keithh
EB70 has a 1000W Inverter. So 260 Watts should be no problem. Interesting is the surge power of the pump. When its turning off and start again.
EB70 have about 700Wh capacity. So it could run for like half an hour on 260 Watts
Thanks for the info Erik, much appreciated.
