Bluetti EB3A not charging (A082 Grid voltage Low warning)
Hello Everyone,
Please kindly help.
I just got the bluetti EB3A a few days now (29th Dec. 23) and the first time I plugged it to the power grid AC Socket it didn’t show any sign of charging. Only shows that the active ‘UPS’ indicator. On the bluetti app, it gives me a ‘AO82 Grid low voltage’ warning, but every electric devices seems to be running fine, the fan, my laptop etc. I also tried to charge it using an AC Generating set. And I get similar warning and the EB3A seize to charge.
Although the AC power output works absolutely well. At the time of purchase, the battery was at 65%. I used it to charge my laptop for a while and it showed the output wattage per time unlike the Input which is not showing when plugged in. Currently the battery percentage is 34%.
Also, I didn’t try charging the EB3A while using it charge other devices .
But getting it to charge is my major challenge.
Please any help will do
Hi @Adeoye1
different electric devices do have different operation voltages. Some devices can go lower than other.
Check, if the plugged cable is connected right and not loose. If possible, try to charge the unit with a other AC Outlet, maybe even a other powerstation.
Do you have a device to measure your Grid voltage? Check it in the next step to make sure your grid is really okay.
Thank you @Selfmadestrom for your response. Apparently grid voltage at my home is either low or unstable. Because this morning, I brought the device to my place of work to try it out and it charged without any issue.
I don’t have any device to measure the voltage at home but I know the power supply often fluctuates.
The thing now is what can I possibly do to solve the voltage issue at home for the EB3A to charge?. Because my sole purpose of buy this power device is to charge my laptop at home when there is power outage. Please any suggestions or advice
Nothing much you can do when you grid isnt stable enough, you cant charge you Unit.
You can buy one of the portable Solarpanels to charge the unit, but that is dependent on the weather.
@Adeoye1 It is possible that the grid input voltage and frequency are not within the range of the machine. You can try adjusting the frequency or changing the socket to test.
I got the same problem. I used my device and went home to charge it because it’s already 35%…
It wont charge, UPS blinking, my app was also updated, and even with 240v socket it won’t charge. I turned it off, let it cooldown and slept…then in the morning, I tried to charge it and it charges now…so maybe it’s the device’s safety to cooldown first before charging…hope it helps! :smiling_face::philippines:
Hi I just got my EB3A about 14 days ago. Im also getting the A082 Error (Grid Voltage Low), A083 Error (Grid Over Frequency) , A0616 (Grid Relay Failure) and A038 (Overall Battery Undervoltage Protection)
I always charge through my AVR and have opnly charged it for like 2 or 3 times, AVR is running at a stable 220V plus all my other apppliances are working fine.
I brought the EB3A to another house from another area just to test if the issue was with my homes power supply but I was having the same erorrs there. The UPS keeps blinking but it wont charge. It was almost drained then I updated the firmware then it went back to 30% but still wont charge. Please help
Hi, i try to charge my bluetti eb3a by generator, it is not working. I got fault code A082 (grid voltage low) and A084 (grid under frequency).
I stay at remote area i use this blueetti to generate power to my router starlink.
The only way to charge it only by generator
Please help me
I am also having the same issue. With a Brand new EBA3 error, Grid voltage low, UPS blinks…It was working fine before was able to charge the unit 1x. but now it’s acting up like it doesn’t want to charge.
Hello, I’m also from PH. How is your Bluetti? Just recently bought this because of the super typhoon. Sadly, It isn;t charging after one day of use. E113 error is the issue.
E113 is Grid Voltage to high. Did you buy the right version? There are different versions for different grid voltages. US only have 120V for example, we in germany use 230V Grid.
Hi @BLUETTI_CARE. I am from Ukraine, and currently we only have electricity for a couple of hours a day. Without a charging station, it’s impossible. But it doesn’t charge properly because the current doesn’t reach 190V in some places. I saw in other threads that it is possible to make custom firmware to enable the station to charge at lower voltages. Please make one for my station.
EB3A
Serial number: EB3A2240003300746
ARM: v2063.02
DSP: v2052.07
Thank you in advance!
Translated with DeepL.com (free version)
EB3A
Serial number: EB3A2308012480683
ARM: v2053.08
DSP: v2052.11
Hi @sklymenko, it appears that you have already filled out the form via the link earlier. We have successfully pushed the new DSP205251 to your device.
Please let us know your feedback.
Hi @Ovechkin, thank you for contacting us.
EB3A
Serial number: EB3A2524001375477
ARM: v2197.02
DSP: v2196.01
Hi! @BLUETTI_CARE After the update, everything works, thank you
Hi @asgardsrei, the new firmware for your EB3A is still in development, and we have reminded our R&D team to expedite the process.
We look forward to bringing you positive updates soon.
Hi @Ovechkin, thank you for your update, we are glad to hear that!
EB3A
ARM: v2197.02
DSP: v2196.01
