Why doesn’t the T200S adapter charger plug fully insert in the charging port of the B80? There is a warning label on the plug to fully insert, but it doesn’t, with normal force. Advice please?
@Qcuser Can you take a picture so I can visualize it better?
Are you referring it’s like this? The tech-team just tested it and confirmed that there is no problem with this, and it will not affect the use.
The caution sticker clearly shows that it should go all the way in.
My T200S connects to the B80 as shown in the photo as well. It appears the barrel was designed a bit too long, however the connection is solid and doesn’t affect charging.
