Since the last version of the Bluetti application (V2.3.1) I no longer see the dynamic animated streams (green) current discharge on the screen? The figures are present (Watts).
This is happening on my Samsung Galaxy Tab A7 lite Android tablet that I use to monitor solar flow and discharge.
Android 14 One UI 6.0 updated in July (dark or light or automatic theme).
By cons, I do not have this problem on my Smartphone Samsung Galaxy Note 20 Android 13 One UI 5.1.
Is this an Android 14 problem?
@BLUETTI
Can you pass the info to the app developers?
That should be a version (Android 14) issue, as we need to adapt to Android 14 recently. It is expected that the version will be fully adapted by the end of August.
My Samsung s23+ phone has no animation at all. September 3, 2024
What do you recommend? I reinstalled the app - the animation did not appear.
Application version 2.3.6
Thank you for the feedback; I have passed it on to the app team.
The team indicated that your situation is an isolated issue and they could not reproduce it, but it has been recorded and they will continue to monitor it.
for update
With application V 2.3.6, no more animation on my Samsung Galaxy Tab A7 lite Android tablet that I use to monitor solar flow and discharge. Android 14 One UI 6.0 updated in July (dark or light or automatic theme).
By cons, with 2.3.6 I do not have this problem on my Smartphone Samsung Galaxy Note 20 Android 13 One UI 5.1.
some weeks ago I noticed this behaviour on my phone after “turn off display animations” for speed up my phone.
Maybe this feature is disabled on Android 14 by default?
@wyse You’re welcome.
I don’t have Android 14 on my phone yet and couldn’t verify it. But I’m glad it was such an easy fix for you and that you’re posting the positive feedback here.
