BLUETTI API to save historical data
Does BLUETTI have API to store historical data from AC300 such as power consumption and battery charge level to draw some graphs in some external(or internal) tool?
Probably not, should be able to use Mqtt to retrieve the data, and then something like home assistant or similar to store and display it.
Cheers,
AP
Okay… Any idea how to use BLUETTI MQTT?
The best option - connect directly to the device, if possible
Hi,
For home assistant there is an add on… GitHub - SSMCD/bluetti2mqtt: Home Assistant Add-on for bluetti_mqtt
I haven’t tried this as I don’t have a Bluetti device with MQTT… yet….
I have used home assistant with Victron mppt’s and other devices.
Cheers.
Ap
