As we all know, the AC500 draws some power out of the wall outlet anytime itās plugged in (33-44W).
I usually leave mine unplugged and in PV Priority mode, but during the night Iāll plug it in to make sure everything stays powered on should the battery SoC drop too low before the sun comes up.
So I have this 1000W Jackery collecting dust that I bought when they first came out. So letās put it to good use by plugging the AC500 into it instead of the wall outlet. Let it provide the 33-44W all day and night, then recharge it during the day when I have power to spare. Sounds good, right?
Well, for whatever reason, the AC500 didnāt like it. The light on my ceiling fan began flickering, and when I checked the AC output voltage of the AC500 it had dropped from the usual 121V to 111V varying somewhat. It went back to 121V the instant I unplugged it from the Jackery.
Not sure whatās going on with that. The Jackery didnāt have a problem supplying the 33-44W at all. Maybe thereās some delay supplying power when called on, and the AC500 took that as an āunpluggedā signal. I could occasionally hear the internal relay of the AC500 click, (happens whenever you plug/unplug from the wall outlet)
Well, this isnāt really here or there. I can live with not using the Jackery like this.
The new APP no longer shows firmware versions and the ācheck for updatesā was removed, so I donāt know what the latest version should be.
I tried but the touchscreen beeps but doesnāt change from 15 amps. Do I need to unlock it with the āsecretā passcode? (I should note that the touchscreen has other problems that are already reported to Support. I didnāt see the need to fix it at this time, but it is on record. AC & DC on/off can only be controlled through the APP, not the touchscreen.)
Well, my Kill-a-Watt meter shows 4 to 5 watts being drawn. I assumed itās a parasitic power draw as with most appliances like my Home Theater gear and even my Keurig coffee machine when itās off. It was the Jackery that was showing the (33W-44W) being drawn.
I was beginning to follow some of thatā¦until I started getting a headache
Go to APP-Home-My device, connect the machine with Bluetooth, you can check the firmware version or upgrade the firmware, the password for the display setting input current is 159873.
Okay, that was sneaky
I never would have guessed that.
āFirmware Upgradeā only appears in the menu if you follow that path. It says Iām up to date.
Touchscreen would not let me change the input current even after entering passcode. Itās stuck on 15A. Iāll get it replaced eventually.
Even after entering the password, the touch screen does not allow the input current to be changed. Do you have the silent mode on? If so, please turn off the silent mode and try to see if you can adjust the current.
