BLUETTI AC2A - Unleash Power Without Compromise
:bulb: Lightest BLUETTI Power Station Ever - 7.95 lbs, easy to lift
:zap: Lowest No-Load Power Consumption - AC&DC on at 7.3W
:rocket: More Portable Design - Hidden Snap-In Handle
:stopwatch: Faster Charging Speed - 80% in 45mins, 100% in 70mins
:mute: Lower Noise Level - Maximum noise below 50db
AC2A/AC70
What else do you want to know about AC2A? Type below! :speech_balloon::point_down:
Since its kinda similar to EB3A. Maybe a little comparision would be great to better decide, which unit does fit better for a special requirement.
Some technical informations like on the website would be also interesting when post about the unit. Like this:
● Total open circuit voltage for AC2A: 12-28V
● Equipped with MC4 connectors.
Highly Recommended:
AC2A: 1x BLUETTI PV200
So it’s EB3A with less power and smaller battery?
Dose it has the same problem that it can’t be recharged via AC if the battery is discharged?
I wouldnt say its exactly like a EB3A but its the next thing which comes near to the AC2A. It does have less Battery and a smaler inverter for sure, but the low self consumption is really interesting when you have your unit on for a long time. Maybe they are even on the same level of usesable capacity over a longer time. Tests will show how it will performed in compariosson to other units.
