Hello everyone, I have found the “BLUETTI AC200MAX” for 1350 euro and I will pair it with a Luxor 24V-540W solar panel to power my gaming pc!
My question’s to the power station owners the main unit when charge from solar and get some AC load like 200-400W the fans is too loud for a bedroom?
I don’t care about the power adapter only for the unit because I found more comments about fan problems and noise.
Welcome to the community
@Koumkouat The noise level of the AC200MAX at a distance of one meter is approximately 55 dB.
So it is fine for a bedroom?
I’d never think of putting my AC200MAX in my bedroom. At least not if I want to sleep there, while the unit is having a load of 200-400W. With this type of load it changes every 1-2 minutes between silence and cooling the unit with the fans active.
When i sleep the unit will not have any load maybe only in the morning when the solar will start send load.
Then it should be quiet. You should switch of the AC output to avoid discharging the battery. Or just swutch it off completely if not using DC either.
Thanks for the tip, when I got the device I will come back if have any questions!
hey, how’s this setup been working for you?
Fine but the fans is not silent you must go for AC200L.
