Bluetti AC180P turn on by itself
Hi!
I have a curious problem. My AC180P is sometimes turning on by itself, if I leave it connected to the AC plug. I turn off it by button or by app, but sometimes it turns on anyway. There are no active connections to the power station when it heppens.
But if I disconnect it from the AC plug, everything is fine.
ARM v2089.02
DSP v2088.02
BMS v1039.01
Why can this happen?
Thx
@Enheter It is normal that you cannot shut down the AC180P while charging.
Hello. My ac180p is disconnected from the 220V network and nothing is connected to it, but it turns on itself, blows through the fan and turns off. after some time it turns on again, blows through the fan and turns off again. How to fix this? I don’t think it should turn on by itself. please help me solve the problem
SN: AC180P2424010070218
ARM: v2089,03
DSP: v2088,03
BMS: v1039,01
