Bluetti AC 180p station, temp error
Hello!
I’ve run into a problem. The battery charge is at 61%, but the station simply shuts down on its own and displays a “temp” error. There was no load on the station. Could you also update the firmware or revert to the previous firmware to ensure the station operates stably?
AC180P2432000609610
IOT: v9046.04
ARM: 2125.04
DSP: 2126.80
BMS: v1048.05
