Bluetti AC 180p station, temp and grid error
The bluetti AC180P2432000609610 station turned off by itself during operation. Currently, when turned on, the temp grid error is on, after 2 seconds the station immediately turns off. Please do a firmware recovery
Temp Grid Error” followed by immediate shutdown may indicate a firmware/control-board issue or a fault related to the inverter/grid sensing system. A firmware recovery/update is often the first recommended step in cases like this, and BLUETTI support typically needs the unit’s serial number and current firmware versions to push recovery firmware to the device. Some AC180/AC180P issues have been resolved through firmware updates
AC180P2432000609610
IOT: v9046.04
ARM: 2125.04
DSP: 2126.04
BMS: v1048.05
