My 2000 has been acting up lately. Wondering if I should discharge it completely and then re-charge it. Would that help to re-set it? And hopefully clear up the current glitch? Is there any danger of damage in doing this? TIA for any help!
Hi @Zeefs
What issue do you have with your curent powerstation (AC200P/AC200Max…?). If you having trouble with the current SoC, for example jumping percentage, you can calibrate the battery by doing at least one full battery cycle.
Discharge you model, if possible with a constant load, and recharge it by AC until its stops itself with charging. Sometimes you need to do this two times.
Error code 06 “Adapter low voltage”. I have fully discharged and recharged the unit. It shows DC output, but none of my DC lights work.
