Is it normal that the Bluetooth is not able to turn on the Bluetti? It states it cannot find it.
I have to physically turn it on then it see’s it and am able to control it and shut it off.
Yes. You can only turn the machine off from Bluetooth. You cannot turn it on.
That’s a bummer. Thanks for the reply though.
Hallo,
is there any other way to turn the AC300MAX on remotley?
It’s very easy to use via Bluetooth and can be scheduled.
if you want to control it remotely (from internet) you also need the hub mini from switch bot.
