BK300 Shared
Is it possible to connect to BK300 the AC300 and AC500, for them to charge the same battery?
Thanks,
Best Regards,
Joao
@bluetti_joaopedrosousaoutlookpt
Do you mean connecting one battery pack to two main units? Sorry, that is not possible. One main unit can have multiple battery packs.
As BK300 have two ports, use one port to connect to AC300 and another to AC500, in this way use the PV strings from both units to charge.
@bluetti_joaopedrosousaoutlookpt Multiple machine communication may encounter abnormal errors, causing the master and slave machines to not function properly. Please be aware.
