Bluetti AC180
Which is the most efficient setting for A/C charging for both battery maintenance/life, and economy of mains power usage (if any) …
As in standard or silent mode …
Many thx ,
Bluetti AC180
Many thx ,
Well, right off the bat, charging the battery from the Grid, there’s not much you can improve on beyond plugging it in and letting it charge. I assume you know to leave AC/DC output swiches off.
The only other way to go is to connect some solar panels so you won’t need the Grid.
Keep the battery on a solid level (at least 10%) and dont leave it too long on a low level.
As for AC Charging, i would recommended to not charge it with full power (less heat generated, longer battery life span)
Hope this was helpful
So on that basis would silent mode be more efficient and cost affective than standard ?
In theory yes because the Fan does not work or on a lower level. Unless you dont need it i would go with the standard mode. Batterys dont like it when they get to hot.
Yes good point there … thx
