I have a ac200max and is better than expected , but have now fitted the D050 enhancer to vans 12v
leisure supply with cut off switch and over night it went from 95% to 22% .
Do I need to unplug overnight if not using
There is a considerable idle power use. Especially with the AC and DC outputs turned on. Switch off your unit when not in use to prevent idle power loss. Or accept the power loss and keep it connected to a power source to keep it charged in UPS mode.
