A300+B300. The only information in the manual about battery care is to discharge the batteries at least twice a year. Does this mean to 10%, or 0%? i just read a reply from Bluetti that told someone to perform 2 full discharge cycles in the first month to calibrate the batteries , however this information is not in the owners manual. I would like clarification on proper discharge and full recharge on the batteries. thanks, and when you say discharge, how low?
@Garry Discharge means discharge to 0%.
The charge/discharge cycle is done like this: Disconnect all charging, take a load, and discharge until it shuts off automatically. Then disconnect all loads and plug in AC or adapter to charge again. Full to 100% (until charging stops automatically)
